Q: During testing, I’d like to process just a single order when exporting from the Faire API to the Faire application.
A: In the initial export from the Faire API, change the Operation from Get All Orders to Get A Single Order By ID. After selecting this option, you'll then see a field to input the ID of the order you'd like to import. Here, you'd type in the Faire Order ID that you'd like to import.
