Error - Format of an element (at index 0) - invalid error object, pre map hook
We are using the salesforce to netsuite IO flows and have been testing this successfully in our sandbox envirnoments. The flows have been configured on production celigo and these have been 'pointed' to our sandbox environments for testing purposes.
Upon successful testing, we attempt to change the flows to use our production environments but when running the sales force opportunity to netsuite sales order flow we receive the following error -
The format of an element(at index 0) in the errors array is incorrect. It must be a plain object containing a code and message. Code - invalid_error_object Source - Pre Map Hook.
We have checked all connects and field mappings. There does not seem to be any documentation on this error.
Has anyone seen something like this or similar that could make point us in the correct direction?
@icsadmin We understand that you are currently working with our support team. Please inform us if you require any assistance. Thank you!
