Do we need an additional subscription for "Push to APIM" in Celigo API Builder?
Hi everyone,
I’m trying to create an API using Celigo API Builder. We already have API Builder available in our subscription, but when I select “Push to APIM”, it asks me to request access.
Does this mean we need an additional subscription or license for APIM, or should this be included with API Builder by default?
Thanks in advance!
Hi @Vikas_Bhandari
Thanks for reaching out!
The API Builder included in your subscription allows you to build and manage APIs. You can use API tokens to authenticate and call these APIs directly. Documentation can be found here: Authenticate and invoke an API ,Managing API tokens.
The “Push to APIM” option is part of Celigo’s API Management(APIM) offering, which provides full API lifecycle management capabilities. APIM is a separate add-on that requires an additional subscription. If you’re interested in these capabilities, we recommend reaching out to your account manager to discuss options and next steps.
