Manually building APIs for integrations can be time-consuming and error-prone, especially when you need to expose data securely and reuse logic across multiple flows. Developers often struggle with scaling custom endpoints and maintaining consistent performance.
In this Builder’s Hub article on API Builder, you’ll learn how to rapidly create, test, and deploy custom endpoints directly within integrator.io. The guide walks through using API Builder to abstract flow logic, manage request-response schemas, and handle authentication, so you can build scalable APIs without writing backend code.
