For the Shopify store, we have enabled the synchronization of orders with pending payments. While these orders sync immediately upon creation, updating an order's status to "paid" at a later time does not trigger the creation of a Customer Deposit (CD) in NetSuite. However, when orders are paid immediately at checkout, Customer Deposits are successfully created.
Why does this behavior occur, and is there a way to ensure Customer Deposits sync to NetSuite whenever an order is marked as "paid" later in Shopify? Order are manully marked as paid in Shopify.
Hi!
Following up here to close the loop on this one, based on what transpired with our Support team in your support ticket.
After reviewing your order and workflow in the ticket, it was confirmed that the behavior you observed is working as designed. The standard Shopify – NetSuite Integration App creates Customer Deposits in real time, at the moment the order is first created. If an order is placed on payment terms and no payment exists at creation, no Customer Deposit is generated — and the flow does not re-trigger when the order is later marked "Paid" in Shopify.
If you need to account for payments that come in after the order is created, there are two options:
- Manually create the Customer Deposit in NetSuite once the payment is received, or
- Build a custom flow that watches for the payment/status update and creates the Customer Deposit at that point.
Thanks!
Celigo's answer matches what we see: the integration app only creates the Customer Deposit when the order is first created. If you go the custom flow route, the shape that holds up is:
- Trigger on Shopify order updates (webhook, or a scheduled export of orders updated since the last run), filtered to financial_status = paid.
- Look up the NetSuite sales order by the Shopify order ID.
- Before creating, check for an existing Customer Deposit on that sales order, so retries or repeated updates don't create duplicates.
- Create the deposit for the paid amount, and log orders whose sales order isn't in NetSuite yet so they retry on the next run.
Manually marked payments often have no gateway transaction ID, so map them to one consistent payment method for clean reconciliation.
Integr8 Cloudware, NetSuite and Celigo integrations: https://www.integr8cloudware.com/
