Custom flows
Here I am building a custom flow, where Related lists has some of the data but sometimes related lists will be empty due to new records. Then, How can I specify the related lists?
Hello @dextaraadmin,
Can you please provide more details on the use case? Is this request for Salesforce or NetSuite or any other application? Where are you seeing the issue? Can you provide screenshots too?
Hi @dextaraadmin @praveenbasani
I face this same issue with Salesforce for Referenced fields and Related lists. I'm unable to select the "Parent sObject type", as no object is being displayed in the drop down.
Can you suggest any solution?
Thank You
Hi @aishwaryamj
We have identified this issue and this is going to be fixed as part of our April release, which is scheduled to release on 16/17th of April.
