Hey
Thanks for the new feature
i did everything but when I want to customize the colorado tax to 0 because we want SO to call Avalara using only that non-inventory item
(Colorado item) the TaxRetailFee it didn't show up in the mappings automatically I add manually when i add the lookup to 0 it didn't change that in Netsuite
Thanks
              Hi @idrisstalainteoulili
Using the Map province retail shipping tax setting, the override will only happen when the override value is not “0". Also, the current implementation is not adding a line item in Netsuite if the price is "0". You can write a custom script in NetSuite to make the value ‘0’ after syncing the order. Let us know if this helps.
Happy posting!
