Batch resolve errors not working
Is anyone else having trouble resolving more than one error at a time?
I check the box on the header of the list of error, which checks all of the boxes for the 50 visible errors. The "Add to batch" checkbox is checked as well, but when I click "Resolve & Next" only one error is resolved at a time.
Hi @coreyschwoebel ,
I'm moving this post to the Troubleshoot custom flows section for more visibility! Thanks!
The bottom right buttons only work on a single record. To retry/resolve multiple errors you can only use the resolve/retry selected buttons that are on the top of the list next to the search bar.
Thank you!
