Anyone with experience in flow creation for Netsuite to Salesforce?
Hello, I’m trying to set up connections between netsuite and salesforce. I thought I’d try setting up Salesorders to Orders flow with the realtime listener, it says its active but I cant get it to trigger so its not functioning. Any advice would be helpful, thanks!
Did you follow these steps?
https://docs.celigo.com/hc/en-us/articles/30439673754267-Listen-for-real-time-data-from-Salesforce
I had no idea about creating the trigger on the salesforce side! I’m trying to get the correct permissions on the correct objects and I’ll give it a try. Thank you!
@nuriensing Was able to help me, he took some time out of his personal day to help me understand the fundamentals of what I was trying to do!
