If you intend to use the default address as the POS address, then you must map the billing address field accordingly as explained below:
- Log in to your integrator.io account with the required credentials.
- Click Shopify - NetSuite integration tile.
- Go to the Flows > Order section.
- In the Order import flow you want to configure the mappings. Next to the flow, click Mappings.
- On the Edit Mappings window, make the changes shown in the following screenshot.
You may edit all billing and shipping addresses to your desired values.
XXX means the value you want to import to NetSuite
YYY means the default node
