Hey Everyone,
Is there a way to generate Walmart API digital signature using Http Connector?
Here is the Link for the Instructions to generate Digital Signature: https://developer.walmart.com/documentation/digital-signature/
We have an actual Walmart connector. Have you tried using this?
I have not looked at the Walmart signature specs before, but there are multiple ways to build custom signatures using handlebars functions, and then we also recently exposed the ability to use the Stanford JavaScript Crypto Library in your JavaScript code. It should be possible to get something working.
If this high level guidance does not help, then it might be best to engage Celigo for some consulting help to try to get it working.
https://docs.celigo.com/hc/en-us/articles/360039326071-Handlebars-helper-reference#hmac
