Q. I see occasional notifications about errors with the code ss_out_of_points. I assume they’re not coming from integrator.io. What are points? How do I stay within a limit if I’m not running any SuiteScript routines, to my knowledge?
A. Each NetSuite API call, typically executed as part of the integrator.io NetSuite bundle, costs a number of “points” as determined by NetSuite.
Certain requests, especially in NetSuite imports, can cause higher point usage, depending on the number of records and associated operations.
There are a few steps you can take to minimize point usage, as detailed in the new Celigo Help Center article, Handle NetSuite point limits (troubleshoot error code: ss_out_of_points).
