Time Calculation Handlebar Help
I have the following Handlebar that calculates the number of hours worked on a job. (Trust me it works). v_NS_Time is populated by a result mapping in a previous step.
{{divide v_NS_Time 87.5}}
Now I want to use this value to calculate an ending date/time field.
Previously I was defaulting an end date/time to 1/2 hour with the following Handlebar
{{dateAdd (timestamp) "1800000"}}
When I try to replace the "1800000" with "360000" multiplied by the handlebar above, then nothing gets mapped as I want it to be. Here is the handlebar that I tried.
{{dateAdd (timestamp) {{multiply 3600000 {{divide v_NS_Time 87.5}}}}}}
Thanks for any help.
try this:
{{dateAdd (timestamp) (multiply 3600000 (divide v_NS_Time "87.5"))}}
Let us know if it works, thank you!
That worked great and it actually didn't need the quotes around the 87.5 value.
Thank you..
