Hi Team,
Currently celigo has both of the features where we can tag errors and it also auto resolves certain errors such as Unauthorized etc. But what would be helpful is to be able to tag/mark certain errors and tell celigo to auto resolve them based on custom requirements.
I have a few flows were there are certain repetitive errors that occur by design. So I have a separate error resolution flow that resolves them using the IO connection based on the export/import ID. But having this feature where I can tell celigo to resolve some errors with out having to build a separate flow for it would make it a lot easier. An example is attached
