Stale Mock Output Fields Persisting in Celigo API Builder Flow Mapping
I have a Celigo API integration and running into a stale data persistence mapping issue. I've added new data to mock output fields at the very first step - API request step, and saved, but they' will show up as available mapping options in the next import step, combined with previous stale data despite I have refreshed multiple times.
Is there a way to fully reset or clear cached mock output fields between API Builder steps?
Hi @kate_moore ,
To clear the cached mock API request fields, please try removing the mock data from the API request step entirely and saving the integration. This should reset the available mapping options in the subsequent import step and remove any stale fields.
If the old data is still appearing as mapping options after doing so, please log a support ticket so our team can investigate further. We have not been able to reproduce this behavior on our end, so a closer look at your specific setup would help us identify the root cause.
Thanks!
Thanks, I reset/ remove/ refresh the mock data and it's still persisted. I submitted a ticket
