When I double click on agent then it's occupying CPU almost 100% and I see in task manager many agents are running.
here are the log details:
{"v":0,"level":30,"name":"newrelic","hostname":"BIPROD02","pid":21388,"time":"2023-09-14T20:50:58.743Z","msg":"Unable to find configuration file. If a configuration file is desired (common for non-containerized environments), a base configuration file can be copied from C:\\Program Files\\Agent\\resources\\app.asar\\node_modules\\newrelic\\newrelic.js and renamed to \"newrelic.js\" in the directory from which you will start your application. Attempting to start agent using environment variables."}
{"v":0,"level":30,"name":"newrelic","hostname":"BIPROD02","pid":21388,"time":"2023-09-14T20:50:58.744Z","msg":"Using New Relic for Node.js. Agent version: 9.7.4; Node version: v14.17.0."}
{"v":0,"level":30,"name":"newrelic","hostname":"BIPROD02","pid":21388,"time":"2023-09-14T20:50:59.001Z","msg":"Using LegacyContextManager"}
{"v":0,"level":50,"name":"newrelic","hostname":"BIPROD02","pid":21388,"time":"2023-09-14T20:50:59.005Z","msg":"New Relic requires that you name this application!\nSet app_name in your newrelic.js or newrelic.cjs file or set environment variable\nNEW_RELIC_APP_NAME. Not starting!"}
{"v":0,"level":50,"name":"newrelic","hostname":"BIPROD02","pid":21388,"time":"2023-09-14T20:50:59.005Z","msg":"New Relic for Node.js was unable to bootstrap itself due to an error:","stack":"Error: New Relic requires that you name this application!\nSet app_name in your newrelic.js or newrelic.cjs file or set environment variable\nNEW_RELIC_APP_NAME. Not starting!\n at createAgent (C:\\Program Files\\Agent\\resources\\app.asar\\node_modules\\newrelic\\index.js:141:11)\n at initialize (C:\\Program Files\\Agent\\resources\\app.asar\\node_modules\\newrelic\\index.js:82:15)\n at Object. (C:\\Program Files\\Agent\\resources\\app.asar\\node_modules\\newrelic\\index.js:37:3)\n at Module._compile (internal/modules/cjs/loader.js:1083:30)\n at Object.Module._extensions..js (internal/modules/cjs/loader.js:1113:10)\n at Module.load (internal/modules/cjs/loader.js:940:32)\n at Module._load (internal/modules/cjs/loader.js:781:14)\n at Function.f._load (electron/js2c/asar_bundle.js:5:12913)\n at Module.require (internal/modules/cjs/loader.js:964:19)\n at require (internal/modules/cjs/helpers.js:88:18)\n at Object. (C:\\Program Files\\Agent\\resources\\app.asar\\node_modules\\@celigo\\rdbms-adaptor\\src\\index.js:8:3)\n at Module._compile (internal/modules/cjs/loader.js:1083:30)\n at Object.Module._extensions..js (internal/modules/cjs/loader.js:1113:10)\n at Module.load (internal/modules/cjs/loader.js:940:32)\n at Module._load (internal/modules/cjs/loader.js:781:14)\n at Function.f._load (electron/js2c/asar_bundle.js:5:12913)\n at Module.require (internal/modules/cjs/loader.js:964:19)\n at require (internal/modules/cjs/helpers.js:88:18)\n at Object. (C:\\Program Files\\Agent\\resources\\app.asar\\lib\\msRouter.js:1:21)\n at Module._compile (internal/modules/cjs/loader.js:1083:30)\n at Object.Module._extensions..js (internal/modules/cjs/loader.js:1113:10)\n at Module.load (internal/modules/cjs/loader.js:940:32)","message":"New Relic requires that you name this application!\nSet app_name in your newrelic.js or newrelic.cjs file or set environment variable\nNEW_RELIC_APP_NAME. Not starting!"}
Log:
Please migrate your code to use AWS SDK for JavaScript (v3).
For more information, check the migration guide at https://a.co/7PzMCcy
2023-09-14T20:51:08.625Z: level=error, logName=uncaughtException, err={"errno":-4048,"code":"EPERM","syscall":"open","path":"C:\\Program Files\\Agent\\server.log.2023-09-14-T20"}, stack=Error: EPERM: operation not permitted, open 'C:\Program Files\Agent\server.log.2023-09-14-T20', message=EPERM: operation not permitted, open 'C:\Program Files\Agent\server.log.2023-09-14-T20'
2023-09-14T20:51:08.931Z: level=error, logName=uncaughtException, err={"errno":-4048,"code":"EPERM","syscall":"open","path":"C:\\Program Files\\Agent\\server.log.2023-09-14-T20"}, stack=Error: EPERM: operation not permitted, open 'C:\Program Files\Agent\server.log.2023-09-14-T20', message=EPERM: operation not permitted, open 'C:\Program Files\Agent\server.log.2023-09-14-T20'
2023-09-14T20:51:09.113Z: level=error, New Relic failed to open log file C:\Program Files\Agent\newrelic_agent.log
2023-09-14T20:51:09.114Z: level=error, undefined
2023-09-14T20:51:10.016Z: level=info, logName=show-logs
