Good Morning,
I am currently trying to import a customer metafield from Shopify to Klaviyo custom property that I made on a profile. I would like to know if it's possible? If so what am I doing wrong?
@shadnerjoseph couple questions:
@shadnerjoseph the drop down of available fields doesn't show custom property fields. I would flip to mapper 2.0 as it's the recommended mapper, and then have "Value Saved" on the left and the mapped Shopify field on the right. However, the error you are getting is the error I received when I used an invalid profile id. Are you sure you are using the Klaviyo person id on your import setup?
Thank you the error was on my end. You were correct as I did not use the correct Klaviyo profile ID.
I have a separate flow to get the Klaviyo ID from Klaviyo and add to the existing customer tags on Shopify and concat "Klaviyo ID:" in the beginning of the ID itself in order to easily pull the ID on the other flow. The issue I'm running into is adding the Klaviyo ID to the customer tags as a new tag without removing the exiting customer tags. Thank you for your help as this has been a ongoing task with multiple complications.
