SFDC OAuth 2.0 Generic Decline
If you're running into issues with the new Salesforce restrictions on OAuth, here's a path we used to reauthorize our org for Celigo.
Reauthorizing Celigo with Salesforce
  1. Authorize the Connection: Have a Salesforce system admin authorize the connection from Celigo to your org.
  2. Find the Connected App: In Salesforce, go to Setup > Connected Apps OAuth Usage
  3. Install the App: Find Integrator_io in the list and click Install.
  4. Configure Permissions: Set up the connected app to match your security policies. We recommend:
    • Relaxed IP Restrictions
    • Pre-authorized Admin Users
  5. Add Your Integration User: Once the app is installed, go to Connected App OAuth Usage. Under the Integrator_io entry, click Manage Profiles. Add the profile for your dedicated integration user to the list of allowed profiles.
  6. Reconnect in Celigo: Go back to Celigo and reauthorize the connection using your integration user's credentials.
