Saved search to pull inventory from specific bins per location?
Figured it out, had to put back internal ID and sort by it
You sure you're quantities are correct with using locationquantityavailable and not binonhandavail? Also you have no grouping.
Sorry that was the wrong screenshot, that was the old saved search. Here's the one I updated and using right now!
So all of this is working for you now?
Yes sir! It's all set up, tested the flows multiple times with various products and pushed it live last night. All inventory reading as I need it to read as of now. Thanks for your help!
