Salesforce Import Glitch
I am trying to Listen the Creates and Updates on NetSuite native record ‘estimate’. I am trying to create corresponding Contract and Contract Item (custom Objects; estimate header data <> Contract; estimate line data <> Contract item) in Salesforce. I am mapping estimate line items to Salesforce Contract Items. The process creates a new Contract and Contract Items in Salesforce when I create a new NetSuite Estimate. Same for the update as well.
When I am adding a new line to an existing NetSuite estimate (which have been already synced to Salesforce) the Salesforce Contract Item step that is supposed to Create a new Contract Item but it ignores the record. If I edit and save the estimate again without making any changes to the lines, the NetSuite listener triggers again and this time the Salesforce Contract Item import creates a new line.
I am not sure why is it not behaving correctly in the first trigger. Anyone faced this issue before?
Hi Sujit,
Thank you for walking through the flow in detail. Based on your description, this behavior is fairly common in NetSuite-to-Salesforce line-level syncs and is often tied to how the listener event payload is structured and how the import step is keyed. Since resolving this requires a closer look at your configuration and how your data is processed, we recommend submitting a ticket with Celigo Support so our team can provide an accurate resolution.
