I have an API that is calling a SQL Import to Insert several fields into a row on a table. Is there any way that I can return the Id field of the inserted row? The Id field is created as an Identity column.
I have tried the following in the Insert SQL for the Import.
INSERT INTO [TableName] ([Fld1],[Fld2],[Fld3]) VALUES ('Value1', 'Value2', 'Value3')
SELECT SCOPE_IDENTITY() as NewId
But I am not sure how to (or if I can) access the NewId field in the Import response so that it can be returned by the API.
@jodyennen I'm not too sure if this works with our database connectors as normally you are specifying your own primary key when inserting your data. In your case, does a primary key get dynamically created upon insertion? You can try to use response mapping here: https://docs.celigo.com/hc/en-us/articles/360054647472-Lookups-and-response-mapping. If that doesn't work, you may need to create a lookup step after the insert to find the row that was inserted and return the primary key.
Additionally, what database are you connecting to? SQL Server, MySQL, Snowflake, etc?
