How to get response in postman while triggering webhook from celigo?
Hello @shivakumaravula,
I have moved your post to the Troubleshoot custom flows section for more visibility. Thanks!
@shivakumaravula, could you provide details (including any screenshots) so that we can understand your case better and help you?
I'm using webhook and postman to insert data into the database/MySQL. After inserting the data into DB I need some response back to the postman.
If you need a response back, then you should follow the pattern on this page where you invoke an import directly via our REST API. https://docs.celigo.com/hc/en-us/articles/8213191419163-Invoke-an-existing-import-through-the-API
