ugenejude
(Ugene Jude)
May 28, 2021, 9:58pm
1
For a name like "John B Doe", I need first name to be "John" and last name to be "B Doe".
While testing the handlebars statement in Dev playground the below statements work correctly.
{{regexMatch BuyerName "([^\s]+)"}} --> firstname {{regexMatch BuyerName "(?<=\s).*"}}-->lastname
But when implemented in mapping and when flow is run, it throws invalid_handle_bar_expression
"Could not compile handle bar \"{{regexMatch BuyerName \"(?<=\\s).*\"}}\" because \"Invalid quantifier ?\" .Please correct and retry"
Why is it not able to compile when it worked in playground. Please help
Hi @ugenejude -
I created a Support ticket for this issue. You should receive an email with the information.
Thanks!
Kate
Hi Ugene -
I hope you're doing well.
Did you happen to come across a solution to this one?
- Merik
Here's where I landed:
{{#compare (regexSearch VendorName " ") ">" -1}}{{trim (substring VendorName (regexSearch VendorName " "))}}{{else}}.{{/compare}}
Explanation:
returns zero-indexed position of first space
returns -1 when string does not contain space
returns substring starting with (inclusive) first space
it should be noted that I've already trimmed my VendorName on earlier export
there would be issues if VendorName had leading spaces
namely, this output intended to be Last Name would be equivalent to First Name
removes whitespace present at start or end of substring
returns period in scenario where string does not contain a space
jakenaydock
(Jake Naydock)
September 27, 2022, 3:33pm
6
@merikducker Thank you for this workaround and explanation!! I ran into the same issue, and was able to get around it with your method. You just saved me a ton of time.
For anyone else wondering, the reason that this error occurs is because Javascript does not support lookahead / lookbehind, and "?" is involved in the process. You will need to find a different way to structure your formula that avoids lookaheads/lookbehinds.
