Hello Community,
I need to filter based upon some more involved string parsing that is awkward for the point and click filter, but which JavaScript can handle easily. However, I cannot find examples as far as referencing the passed in JSON data. For other hooks, such as pre-map, there is the options.data[].fieldname format with function premap(options) syntax. In the filter, the object is "record" instead of data. I have tried, for example:
function filter (options) with options.record[0].amount, record[0].amount, record.amount, and just "amount"
I have also tried "data" instead of record, and tried using "record" as the passed in parameter.
Unlike the other J-Hook locations, this one does not offer a stub, which would be helpful.
Thank you for any insight into how to reference these data fields.
Jim
