I am attempting to create a preSend Celigo Hook. I have taken the sample from here:
https://github.com/CeligoServices/SuiteScript-Hooks/blob/master/preSend/samplePreSendHook.js
However, it is not working. The logs are showing that the record was sent to Celigo, however it is not causing the flow to run. I also cannot find any logs that the hook ran in the Celigo Realtime Import Restlet Runner. I am using suitescript 1.0 as directed. Could you help me to figure out why this is causing the flow not to run?
Thanks,
@baileyfeldewerd on the export step, what option is selected here? If your hook is in suitescript 1.0, then it needs to be using suitebundle 1.0 or suiteapp 1.0.
@tylerlamparter
Yes, I have had it set to the 1.0 SuiteBundle. Which is what I have installed in Netsuite.
@baileyfeldewerd It looks like the execution log for this is actually under the "Celigo Consumer Runner" script deployment. I went to script execution logs for the entire NetSuite instance to find where it was going.
@tylerlamparter
That's correct! After looking at these logs and changing the sample script to actually perform the update I was trying to do, everything worked!
Thank you!
