Parse_Error Due to Quote
I got a new error while parsing a CSV file for a Netsuite integration. Any advice here would be helpful.
"Code": "parse_error",
"Message": "Invalid Closing Quote: found non trimable byte after quote at line 3",
"source":"application",
"classification":"parse"
Hello Swaroop, there must be an unescaped double quote in that line, you'll need to fix the import so that it doesn't include double quotes. Here is an article I found that outlines the five most common CSV import errors and how to fix: https://medium.com/@francois.barbanson/5-most-common-parsing-errors-in-csv-files-e6a7e46b9303
Hey Joe, thanks for the response, will follow the same.
For the Amazon IA, make the setting changes using the article below to fix this issue for:
FBA Inventory Adjustments
FBA Returns
https://docs.celigo.com/hc/en-us/articles/19424382232603-Edit-Async-helper-to-disable-quote-validation-and-strip-enclosing-quotes#edit-async-helper-to-disable-quote-validation-and-strip-enclosing-quotes-0
