NetSuite Invoice Messages To Salesforce
Is it possible to push the messages attached to a NetSuite Invoice to Salesforce? Most likely this will need to be done at the Customer/Account level as the Financial object in Salesforce does not have a related section.
Hi Nathan, are you referring to the records/messages under the Communication-> Messages subtab on the Invoice Record? If so, this can be achieved by adding a new flow on integrator.io that will sync this info from NetSuite Invoice record to any corresponding Salesforce object depending on your business needs
