Use Case: We have webforms that currently submit directly to NetSuite via their Forms. However, we need more flexibility over these forms, how they submit, and error messaging.
I have been attempting to use the MyAPI and imports to migrate the processing and mapping of these forms through Celigo. I have a passthrough Lambda function I plan on using to get the information to Celigo. However, a bit of a blocker in that ideally, I would have a listener that would listen to the Lambda and process the information, but that doesn't seem possible.
The other solution I'm working on is the MyAPI and running two different imports back to back to get the information into NetSuite. The first import maps to the customer, and the second maps to the Case form using the customer id.
I'm trying to figure out if I'm on the right track, or if there's a better solution that's been used than what I'm trying.
@chriscoppenbarger Thanks for posting to the community. It looks like invoking imports through MyAPIs should work as you explained. However it would be great to connect and go through the use case before providing any recommendations.
I did successfully get one import to run correctly. I'm not sure if I have the way of running the second import correctly, or not. I'm posting a screenshot of my integration, and sample code from my script. I need the customer id returned from the first import to run the second import.
import { request, exports, imports, flows } from 'integrator-api' function handleRequest (options) { let method = options.method; let body = options.body; let queryString = options.queryString; // Get the input data that are passed in the records attribute in the request let recordsToBeImported = body.records;
let contactResponse; let regResponse; try { contactResponse = imports.run({ _id:'******', data:body }); }catch(e) { contactResponse = JSON.stringify(e) } if(contactResponse.length > 0){ try { regResponse = imports.run({ _id: '******', data:contactResponse }) } catch(e) { regResponse = JSON.stringify(e) } } // Build response information let response = {}; // Set the response status code response.statusCode = 200; response.body = { method: method, body: body, queryString: queryString, finalResponse: contactResponse } return response; }
I recommend using 'console.log()' in your JavaScript code to inspect all the different objects, and then it should be easy to piece it all together. To view the logs, see pic below for context.
At a very high level, if you need to mash up a bunch of different imports (i.e. API calls to different apps), and also get the results of all the API calls in the original HTTP request + response, then MyAPI is the way to go. If you do not need the results of all the different imports in the original HTTP request + response, then I would recommend sending your API requests to a "Listener" bubble in a normal flow that can do all the work behind the scenes.
Regarding your code, here is some high level guidance that might help too.
contactResponse._json is a generic container variable that we use to return back all the information from the external API. This is where you should find the NetSuite id.
For your second import, you can create the perfect 'data' payload that matches the import2+mappings. i.e. you can take fields from 'body' and '_json' and then submit a brand new object.
Thanks for the reply. If figured how to "listen" to my AWS Lambda as a webhook. My current issue is getting the HMAC authentication working. I got it working in Postman using one example from one of the posts here, but having an issue in my Node.js code. It's not a Celigo issue, in this case, obviously, but any ideas?
let hmac = crypto.createHmac("sha256", HMAC_SECRET).update(JSON.stringify(postData)).digest("base64");
where postData is:
"records": [
"first_name": "Demo",
"last_name": "MyAPI",
"email": "tes1234@nospan.com",
"street_address":"123 first street",
"city": "columbus",
"state_or_province": "ga",
"zip_code": "31804",
"country": "usa",
"phone":"123-456-7890"
I keep getting 401 unauthorized. Secret is same as I put in my Listener on Celigo.
