Mapping sales order custom Shopify fields with Handlebars when Hooks are not available
This is for the Shopify to Netsuite sales order flow. We have custom fields in shopify order, see the bottom of this post. I want to be able to transform and map these fields into a netsuite custom field that is likely to be "shopify_subscription_percentage".
I need to have logic to check another field "note_attributes" in the order to determine if the order is an "initial_subscription" or "recurring". If initial then use the inital percentage, if recurring, use the recurring one.
Is this possible with handlebars if i add a new mapping field to the flow? (see below, i think not). If i need a hook, I assume that it is not possible, as hooks are not allowed in the IA, is that true?
// order has an array of:
"note_attributes": [
"name": "_subscription_order_type",
"value": "initial_subscription_only"
"name": "_payment_method",
"value": "shop_payment_method_2054"
// for each line_item in the order, there is an array:
"properties": [
"name": "_subscription_recurring_discount",
"value": "percentage:5"
"name": "_subscription_frequency",
"value": "1_week"
"name": "_subscription_line_item",
"value": true
"name": "frequency",
"value": "1 week"
"name": "_subscription_initial_discount",
"value": "percentage:10"
After working on the handlebars in Playground, i can read the values in each array but i cannot use note_attributes to determine the value we select from line_item properties.
# note_attributes array:
{{#each order.note_attributes as |attr|}}
{{#compare attr.value "==" "initial_subscription_only"}}
order type = initial subscription!
{{/compare}}
{{/each}}
# line_item properties array:
{{#each order.line_items as |line|}}
{{#each line.properties as |prop|}}
{{#compare prop.name "==" "_subscription_initial_discount"}}
initial discount = {{prop.value}}
{{/compare}}
{{/each}}
{{/each}}
# (output) note_attributes array:
initial discount = percentage:10
My conclusion is that this can't be done with Handlebars, we would need a javascript hook in the IA. So what should we do?
Hi @jolyonblazey could you please raise a support ticket so that the right team can look into this? Please look into this document for information on submitting a support ticket. Thanks!
I have done this @sairachamalla; sorry, i thought it would be of general interest in terms of how you can 'customise' an IA, but it is probably too specific.
