Hi all,
I need to be able to automatically populate the serial lot number.
My current set up is to do an Item look up for serial lot, but I am getting more than one result, because I have multiple serial lot per item.
Is there a way for me to grab one with the most available?
Is also a way for me to add a filter "greater than or equal to" to Inventory Location : Available?
Looks like a duplicate thread going over here in case anyone else runs into this. https://netsuiteprofessionals.slack.com/archives/CFG7DNCM9/p1682015369032499
Hi @tylerlamparter, is it possible to read through the above case? I could not access the link because I'm not part of the NetsuiteProfessionals workspace.
@ezelle I forgot that the NetSuite Professionals Slack workspace is non paid and therefore doesn't keep chat history past 90 days. Next time I'll make sure to copy the information over here. @weifengyang if you remember how you resolved this, maybe you can post the answer here?
Hello I ran into the same issue here - is there an answer here to this question? @tylerlamparter
@ianluck @ezelle you can find the archive on the NetSuite professionals website: https://archive.netsuiteprofessionals.com/t/10390091/hi-has-anyone-done-a-custom-flow-on-celigo-to-create-item-fu
