Hi,
I run into these issues daily and thought I'd stop and share with the Celigo team. If any other users have additional issues, please add to the thread!
- Can't use arrow keys to select from field suggestion list - when the suggestion list pops up you need to use your mouse to click on an entry. It would be better if I could arrow down to select the match I want, then press enter and have it commit the line (and maybe start a new one? Or move focus to the "add rule" icon so I can press enter to start another)
- Leaving focus from a field with a suggestion list doesn't hide the list - If you tab out of a field the list remains visible and it takes interacting with the mouse to get rid of it. Maybe ESC works, but either way it should hide when focus is lost.
- Where does focus go after you select an item from the suggestion list? Suggest going to the add rule icon of if the destination field is empty, maybe focus there?
- ESC key has slight delay when hiding suggestion list - minor, but mildly annoying
Basically the editor is painful to use if you want to keep your hands on your keyboard and avoid the mouse.
