Making a Connection with No Authentication
I haven't run into this before, but I have a system that I need to Post data to and they are telling me that they don't use any level of authentication. Specifically, they said in their email to me that:
"Usually we just had a hash that you pass and/or we restrict the IP the posts come from."
My question is, is it possible to build a connection to this system if no authentication is being used on their side? Is so, what option do I select when building the authentication for the connection in Celigo?
Hi @daveguderian,
It is possible to create an HTTP connection with no authentication.
Let us know if you have any further questions!
Thanks.
@daveguderian the doc @kathyanaqueeman linked needs to be updated so we'll work on that. You just have to:
  1. Name your connection
  2. Set your base uri
  3. Set your media type
  4. Set your auth type = custom
  5. Save
Thank you both Kathyana and Tyler. I appreciate the help!
