Jira Update Transitions Not Supported?
Good day! I see in the Celigo supported Jira APIs that GET issue transitions are supported, but UPDATES are not listed. Is it safe to say that Celigo cannot transition the status of a Jira issue, or am I missing something?
Thanks!
Mike
@mikedarretta I assume you are needing this api? If so, you can flip your form view to "REST API" and then put the relative uri in for that endpoint. You can switch this form view for just about any connector to hit endpoints that we have not yet added to the drop down menus.
