Iterate through rows and sum values - Using Transformation 2.0
Hi,
Could anyone give me some guidance in how to iterate through rows and create a value of all sub values.
The goal is to get a new value of TotalBoxesperPallet from BoxesperPallet values in each row.
Any guidance on the would be great.
Thanks in advance.
I would switch over to a JavaScript transform. I highly recommend using AI to write JavaScript code now days. You can do it in the product directly, and I promise we have a better UX coming soon, or you can do it in ChatGPT outside the product too.
Hi Scott,
Thanks for the direction, I have thrown it into ChatGPT and got exactly what I needed for the flow, after a few tweaks to the prompts.
For anyone who comes across this, and would like to know the solution I got to in the end.
Using Javascript transform…
function transform(options) {
  const formatDateString = (dateStr) => {
    const [day, month, year] = dateStr.split("/");
    return `${year}-${month}-${day}`;
const data = options.record; // Input JSON data
const transformed = {
ShipmentID: data[0].ShipmentID,
Carrier: data[0].Carrier,
Reference: data[0].Reference,
ShipmentDate: formatDateString(data[0].ShipmentDate),
DeliveryDate: formatDateString(data[0].DeliveryDate),
DeliveryTime: data[0].DeliveryTime,
OrderNumber: data[0].OrderNumber,
CustomerPO: data[0].CustomerPO,
OrderMemo: data[0].OrderMemo,
LineDetails: ,
OrderTotals: {
TotalUnits: 0,
TotalBoxes: 0,
TotalPallets: 0,
TotalProducts: 0
UniqueSKUs: new Set() // Temporary set to track unique SKUs
// Process each line
data.forEach(item => {
const {
Pallet,
SKU,
Batch,
Expiry,
UnitsinBox,
TotalUnits,
BoxesperPallet,
“Pallet Weight”: PalletWeight,
Dimensions
} = item;
// Add LineDetails
transformed.LineDetails.push({
  Pallet,
  SKU,
  Batch,
  Expiry: formatDateString(Expiry),
  UnitsinBox,
  TotalUnits: parseInt(TotalUnits, 10),
  BoxesperPallet: parseInt(BoxesperPallet, 10),
  PalletWeight,
  Dimensions
// Update OrderTotals
transformed.OrderTotals.TotalUnits += parseInt(TotalUnits, 10);
transformed.OrderTotals.TotalBoxes += parseInt(BoxesperPallet, 10);
transformed.OrderTotals.TotalPallets += 1;
// Track unique SKUs
transformed.UniqueSKUs.add(SKU);
// Finalize TotalProducts by counting unique SKUs
transformed.OrderTotals.TotalProducts = transformed.UniqueSKUs.size;
delete transformed.UniqueSKUs; // Remove temporary set
// Assign the transformed data to options.record
options.record = [transformed]; // Single record in an array
return options;
If that is still your goal, you can totalize the BoxesperPallet with a single line of code:
//  @Celigo - there is a bug that is adding the string "Copy" to formatted code blocks
const totalBoxes = options.record.reduce((acc, cur) => acc += parseInt(cur.BoxesperPallet), 0)
There is a lot more going on in that code and I can't tell if it's just garbage chat GPT code or if your actual needs are much more complicated than your original stated desire.
I do this by creating a transformation that maps rows[*].boxesperpallet to a string array named boxesperpalletarray.
Then, you can do a {{sum boxesperpalletarray}} handlebars expression in your import mapping and you'll have the total. Easy and no code needed.
