Hi,
I'm having an issue with mapping multiple schemas in a string array for the destination schema field in Concur on the import mapping. For starters, when I am using Mapper 1.0, all of the fields were inputted correctly but I continue to receive a schema error. I wish I had saved the preview results before I attempted Mapper 2.0, but the results would be something like in the screenshots below. My integration is to export data from UKG Pro and import to Concur Expense. I tried looking through articles and the Celigo community, but couldn't find any answers.
Mapper 1.0:
What it outputted:
"urn:ietf:params:scim:schemas:core:2.0:User,urn:ietf:params:scim:schemas:extension:enterprise:2.0:User,urn:ietf:params:scim:schemas:extension:spend:2.0:User,urn:ietf:params:scim:schemas:extension:spend:2.0:Role,urn:ietf:params:scim:schemas:extension:spend:2.0:Approver"
Mapper 2.0:
What it should have outputted in the preview:
As you can see, both are using the exact same settings but each is outputting the schemas field preview differently. I thought I would just switch to Mapper 2.0 instead but am running into a separate issue there where I need to send multiple customData types like I did in Mapper 1.0, but am running into a uniqueness issue with 2.0:
Mapper 1.0:
Mapper 2.0:
If I can get the first issue with schema in Mapper 1.0 resolved, then I won't need to use Mapper 2.0. Else, I'll need to use Mapper 2.0.
