Issue with Multi-Flow Routing in CBR Script — Only First Flow Executes
Hi Celigo Community,
We are facing an issue with a Content-Based Routing (CBR) script where returning multiple flows for a transaction type only executes one flow.
What we observed
  • The CBR script returns an array containing two flow/export ID objects for certain transaction types.
  • Only one flow executes — specifically, whichever flow appears first in the array.
  • Swapping the order of the flows changes which one executes, confirming the issue is position-dependent rather than flow-specific.
  • We tested both array-based returns and alternate syntax approaches, but the behavior remains the same: only one flow triggers.
  • The issue occurs consistently across all transaction types configured with two flows, including 852, 860, 864, and 820.
  • Returning a single flow object works correctly throughout the script.
Additional context
  • All flow/export IDs referenced in the arrays are active and valid.
  • Single-flow routing works as expected.
  • The issue is not isolated to a specific transaction type or flow configuration.
Has anyone implemented multi-flow routing successfully in a CBR script?
Could you please advise on the correct approach to ensure both flows execute as expected?
I’ve attached the script for reference.
CBR_Script.txt (6.0 KB)
Hi Sriram, I'll check in with the Celigo engineering team, but just based on your testing I would assume that we can only submit the file to a single flow/exportid. I see in your script you tried a few attempts, with the single file submission result. The alternatvie would be to pass the file to a flow in IO, store to a temp location, and run secondary flows to process the data multiple times.
