Hi all,
I'm encountering an issue with dynamically setting a fieldmap value in my integration settings. Here is the situation:
I have a script to set the value of a fieldmap based on whether we are in a production or sandbox environment. While the script executes and changes the value, I do not see this updated value reflected in the flow. Instead, I continue to see the manually entered value that was saved previously when the input was not disabled. Below are screenshots illustrating the issue.
In the flow itself:
I want to dynamically set a setting value to determine if we are in a production or sandbox environment. This is necessary because certain mapping values differ between production and sandbox. By doing this, we can avoid manually changing the values every time we pull from one side of the integration. Here is the script in my settings:
function INIT_SETTINGS (options) {
if (options.resource.sandbox){
options.resource.settingsForm.form.fieldMap.environment.value = "sandbox2"
}else{
options.resource.settingsForm.form.fieldMap.environment.value = "production"
return options.resource.settingsForm.form
The JSON of the settings:
"fieldMap": {
"environment": {
"id": "environment",
"name": "environment",
"type": "text",
"helpText": "Environment of the Celigo Integration, this is needed for example to set the right order source in the flow.",
"defaultDisabled": true
"layout": {
"fields": [
"environment"
For now I am using a workaround:
I have created a settings text value and kept it empty in both PROD and SB. Then I filled in the PROD with the value "production" and pulled the PROD into SB. After that, I entered a value in SB settings. Now, I am not getting any conflicts. Thanks, @basvanditzhuijzen for this workaround. The only thing here is that when pulling from SB > PROD that the value in PROD changes to sandbox, which then need to be changed manually again.
This workaround is quite tedious, but it seems to be effective for now. If anyone has a more streamlined solution, I would love to hear it!
