Issue Backing Up Files in S3 Export
Hi all,
I’m trying to configure a flow that uses a specific Amazon S3 bucket to retrieve .json files in a subfolder, and then move (back up) those files to a separate folder after they are processed. In the settings I define:
  • My Bucket name (let’s call it “my-bucket” here)
  • The path to the S3 folder containing the files I want to process as Prefix
  • The path where I want the files to be moved after they are processed as Backup bucket name
When I test the flow, Integrator does retrieve the file(s) for processing, but once it’s done it moves the files in a way that I didn’t expect.
  • Source: s3://my-bucket/partners/corvelay/DEV/INBOUND/purchaseorders/NEW/
  • Expected destination: s3://my-bucket/partners/corvelay/DEV/INBOUND/purchaseorders/PROCESSED/
  • Actual destination: s3://my-bucket/partners/corvelay/DEV/INBOUND/purchaseorders/PROCESSED/partners/corvelay/DEV/INBOUND/purchaseorders/NEW/
Why does the export join the source bucket and prefix with the backup prefix? How can I get it to move the files cleanly to the S3 folder of my choice without moving the entire directory?
It's because that's only the "backup bucket name," so we take your file key (partners/corvelay/etc/file.json), which is everything after the bucket name, and simply move that to the other bucket (backup bucket name + retrieved file key). It's currently not possible to customize the backup file key to do what you're wanting. You could make another bucket, such as my-bucket-processed, or move to a pattern like my-bucket/PROCESSED.
I'll also copy your post to Product Feedback since this would be an enhancement request for custom backup file keys.
Thank you for clarifying and moving to the product feedback forum! I’ll add some more detail there about my use case and why this feature would be useful.
