Insert decimal into Non number
I am working to import cost data into Salesforce, the value lists as 1499, I have tried to use the tofixed function, but it outputs the following when I attempt to transform the value I am getting the following output: NaN1499
{{toFixed field 2}}{{plan.amount}}
try {{toFixed plan.amount 2}} everything needs to be inside the handlebars.
That works to add the decimals to the end, the item cost if 14.99, so I need to insert the decimal at the third and fourth characters essentially. I have been able to do this with replace, but since there will be multiple values would prefer to be able to simply insert or convert the value to a number or currency.
@timkrull can't you just divide by 100?
{{divide plan.amount 100}}
