@Yonton_Mehler asked a great question:
“How can I have a flow that takes tens of thousands of records, imports them somewhere like a database or file, then waits on that step until everything is processed before moving on?”
We talked through a couple options, and I shared one approach — but I couldn’t resist actually testing it. Here’s what I came up with.
Why this matters
This is really useful if you need to insert a large batch of records and then run an action after all of those records are done.
The way I’ve normally handled this is by creating two flows:
- One flow inserts records into a staging table.
- That flow then triggers a second flow that merges staging into production.
That approach is straightforward and honestly easier to manage. But I wanted to see if it could be done inside a single flow. The trick is using the async helper.
Step 1: Get your records
Start with your source. In my test, I used a dummy source, but it could be Salesforce opportunities, NetSuite sales orders, or whatever you’re working with.
On this step, add a preSavePage script to capture pageIndex and recordIndex.
- Later, you can filter on
pageIndex = 0 AND recordIndex = 0to make a downstream step only run once (since only the very first record passes through).
Heads up: if your flow branches, pages can split and arrive in a different order, so this trick may not work further downstream.
Step 2: Insert into your target system (the key step)
This is the step where you want the flow to wait before moving on.
Each flow step creates a child job. You need that child job ID so you can check its status later.
- Use a
postSubmitscript on this step to grab the child job ID. - Add that ID back into your data so the next step knows about it.
Step 3: Add a “waiter” step
Now it’s time to pause until everything finishes.
Use the async helper with the child job ID:
- It checks the job’s status.
- When it’s complete, the flow continues to the next step.
You can repeat this pattern multiple times if you want to add more “wait points” in your flow.
Script
function pageIndexAdder (options) {
for (let [index,d] of options.data.entries()) {
d.pageIndex = options.pageIndex;
d.recordIndex = index;
return {
data: options.data,
errors: options.errors,
abort: false,
newErrorsAndRetryData: []
function jobIdAdder (options) {
console.log(JSON.stringify(options))
for (let d of options.responseData) {
d._json.jobIdToHold = options.job._id;
return options.responseData;
Screenshots
"status": "in_progress",
"jobIdToHold": "{{batch_of_records.0.record.jobIdToHold}}",
"batchSize": {{batch_of_records.length}},
"results": [
{{#each batch_of_records}}{"index": {{@index}} }{{^if @last}},{{/if}}{{/each}}
"results": [
{{#each data.results}}{"index": {{@index}} }{{^if @last}},{{/if}}{{/each}}
Flow ZIP
68b09bcce744dace43f3c532.zip (9.8 KB)
