Celigo developers are currently investigating unexpected behavior for XML transforms caused by recent releases, but we've added a new feature called XML parser helper to integrator.io. It mimics the legacy UI's XML transform behavior.
Use the following steps to fix a transform originally created in the legacy UI to work as expected in the current UI:
- Edit your Source application.
- In the How would you like to parse files? section, click Launch under the XML parser helper.
- In the XML parser, set the Resource path to use Automatic parsing.
