HOW TO: Avoid URL encoding of special characters
While this formula works if you don't have special characters like apostrophes in your values:
 {{trim (split supervisor "," 1)}} {{split supervisor "," 0}}
that doesn't help when dealing with more complex values, like O'Shanahan, as it will render the hex value for the apostrophe (Edward O'Shanahan). {{ }} will URLencode any URL-encodable characters, while {{{ }}} will remove the URL encoding. In this case, use
{{trim (split supervisor "," 1)}} {{{split supervisor "," 0}}},
which will give you Edward O'Shanahan.
