Hi,
When you are creating input filters on flow steps Celigo will show preview/example data in the input tab of the 'Define input filter'-form.
Sometimes this data is cached, sometimes it is sourced real-time from previous export steps.
How does Celigo decide which of the two options to go for?
My first thought was cached for POST and real-time for GET, but some testing confirms it does not work like that.
And related to this, is there a way to toggle between the two options, and set fixed cached preview-data? For example I've got some transactional POST exports that I never want to trigger as a preview, and some NetSuite saved searches that not always return data, and so are very difficult to map when there is no preview data.
