How do I separate the file per process using custom flow FTP to FTP?
Hi, I encountering a minor issue wherein I have to parse 2 or more XML files from FTP going to FTP but in JSON format. Once I process the files, it keeps merging the record and giving me 1 file as a result. What I want to achieve is if I have a 2 or more files. I should expect 2 or more files also as a result after the process.
Thank you!
@marioabelangojr are the XML file names different? If so, you can just have another export on your flow since each export creates it's own file. Just use the file filter options to get just the file you need.
Yes the filenames are different, but the file name don't have a specific format. I already tried adjusting batch, skip aggregation and page configuration but still getting the same result
@marioabelangojr I'll say there isn't a great solution here, but I'll give you one that works if your files are under 5 MB each.
If your file is under 5 MB, then:
  • Set page size to 1
  • The export of files should be set to not parse the files
  • Add a lookup step to lookup files from the FTP and use handlebars to get the file with the filename given from your export step
  • The lookup will parse the file
  • Response map your data to your record
  • Have an import to JSON
  • The import will be set with skip aggregation
  • The import will probably need the one-to-many path set to the response mapping of the lookup
if(options.data && options.data.length>0){
for (let i = 0; i < options.data.length; i++) {
options.data[i].fileName=options.files[i].fileMeta.fileName;
options.data[i].fileSize=options.files[i].fileMeta.fileSize;
return {
data: options.data,
errors: options.errors,
abort: false,
newErrorsAndRetryData: []
@marioabelangojr here is a zip file you can use as well for what I made.
https://drive.google.com/file/d/1smU15NxItfyv7MDCOZfccMKzCl5CbN1o/view?usp=sharing
Thanks for this Tyler, I will give a feedback once I tried this approach.
Hi @tylerlamparter, have you tried setting the page to 1 then try to check the skip aggregation? So you only need two flow instead of 3? Is there a pros and cons using the approach you did vs the configuration I did? Your input is appreciated. Thanks!
@marioabelangojr you could do that, but then you would end up with 1 JSON file per page.
Hi Tyler, can you elaborate it more what do you mean by 1 JSON file per page? I just want to understand it further. Because after I configured the 1 page then skip aggregation. I finally achieved the result, where in I process 3 files then get 3 files as a result.
@marioabelangojr yeah it all depends on your setup. Here are some scenarios below:
  • 3 files, 1 record per file, page size set to 1, skip aggregation set to true =====> 3 files because there are 3 pages
  • 3 files, 2 records per file, page size set to 1, skip aggregation set to true =====> 6 files because there are 6 pages
  • 3 files, 2 records per file, page size set to 20, skip aggregation set to true =====> 1 file because there is 1 page
  • 3 files, 100 records per file, page size set to 20, skip aggregation set to true =====> 15 files because there are 15 pages ( (3 files * 100 records per file) / 20 records/page)
  • 3 files, 100 records per file, page size set to 1, skip aggregation set to false =====> 1 file because it aggregates all files and records together
Hopefully that clears it up.
