I keep getting this at the end of a flow, that posts something using HubSpot. I'm thinking this error is because HubSpot returns `SUCCESS` text instead of JSON after successful request. I'm looking for a way to ignore errors like this from appearing in the error list during runtime. However, I can't find a way to do it.
I tried doing it using postSubmit, but it doesn't even reach there since it can't parse it to a JavaScript Object. Is there a way to solve this?
Message:
An invalid JSON is sent in the response.body, error: please ensure that you have wrapped all JSON property names in quotes. details: Unexpected token S in JSON at position 0
Code: invalid_json
Source: HubSpot
Timestamp: 2022-12-20T21:21:10.858Z
Error ID: 1412159407
Classification : Parse
Trace key : 56851 - 56801
