This is a new error for me. I'm receiving the error:
getListObjectsConcrete should return an array of objects
This is on a flow that is under active development, so I can't say for certain that it started after the update Yesterday, but I do suspect it did. I could be wrong though.
I've gone over the mappings and the data and I can't find anything wrong. I debugged the connection and things look correct, though I'm not sure I'd catch an issue there unless it was pretty obvious. Below is the debug for the Import that is throwing the error.
"method": "POST",
"uri": "https://0000000-sb1.restlets.api.netsuite.com/app/site/hosting/restlet.nl",
"qs": {
"script": "customscript_celigo_io_restlet_runner",
"deploy": "customdeploy_celigo_io_restlet_runner"
"headers": {
"Content-Type": "application/json",
"Authorization": "********"
"json": {
"flowId": "000000000000326ab35b324a",
"_importId": "000000000000326ab35b324a",
"settings": {
"import": {}
"import_da": null,
"_connectionId": "000000000000b765f1c806ce",
"_flowId": "000000000000326ab35b317f",
"_integrationId": "0000000000008569b055487a",
"debugMode": true,
"import": {
"internalIdLookup": {
"expression": "[\"internalidnumber\",\"equalto\",\"{{{id}}}\"]"
"mapping": {
"fields": [{
"generate": "internalid",
"lookupName": "idLookup-update-id-1695961931911"
"lists": [{
"generate": "item",
"fields": [{
"generate": "custcol_overfulfilled_adjustment",
"extract": "_PARENT.adjustmentIID",
"internalId": true
"generate": "line",
"extract": "*.line_id",
"isKey": true,
"discardIfEmpty": false,
"immutable": false,
"internalId": false
"generate": "_keys",
"hardCodedValue": ["line"]
"lookups": [{
"name": "idLookup-update-id-1695961931911",
"recordType": "itemfulfillment",
"resultField": "internalid",
"allowFailures": false,
"expression": "[\"internalidnumber\",\"equalto\",\"{{{id}}}\"]",
"_isOperationalMapping": true,
"_importOperation": "update"
"restletVersion": "suiteapp2.0",
"operation": "update",
"lookups": [{
"ignoreExisting": false,
"ignoreMissing": false
"captureReqAndResData": true,
"data": [null],
"preMapData": [{
"id": "28038",
"item": "X",
"item_iid": "892",
"line_id": "3",
"qty_overfilled": "22",
"_PARENT": {
"subsidiary_iid": "23",
"lines": [{
"subsidiary": "X",
"location": "X",
"location_iid": "225",
"item": "X",
"item_iid": "892",
"adjustmentIID": 289062
"operationalLookups": [null],
"errors": [
"code": "mapping_error",
"message": "getListObjectsConcrete should return an array of objects",
"source": "connector",
"resolved": false,
"occurredAt": 1695961931918
"maxResponseBytes": 10485760,
"timeout": 900000
I'm stumped, not sure where to go with this. I opened a ticket with support (#197266) but still thought I'd ask here as there is urgency on this project.
Thanks for reading and any help you can provide.
Steve
