Generating ISO 20022 XML Files
We’re working on a new project to take payment records and generate ISO 20022 pain.001 (XML) files to send via SFTP.
Would I just use the SFTP integration, select XML, and manually format the output? Is there a better format to use with Celigo or a better option in general?
The way you’re thinking is the best way.
