Hi everyone, it appears that in an FTP to FTP transfer the destination filename must include a timestamp or guid. I want to transfer the file keeping the original name which I know to be unique. How can I accomplish this?
I want to use just {{{data.fileMeta.fileName}}} but the UI has an error and states
Please append date and time stamp, such as {{timestamp "YYYY-MM-DD hh:mm:ss" "America/Los_Angeles"}}
The system I'm uploading to needs to have just the original name.
This is required if you have the Advanced "Skip Aggregation" option in the import step set to true (checked). When Skipping aggregation, this means that multiple files will be uploaded to the FTP endpoint. The Timestamp option is then required because the timestamp (so long as it includes seconds or milliseconds) in the filename will be different for each file that gets created by the import. Otherwise, the files that are being created on the FTP server will be overwritten one after another until the last file is written, causing a loss of data.
To remove this requirement, uncheck the "Skip Aggregation" option in the FTP import step.
A workaround is suggested in this community post, I hope this is helpful for you. If you have any questions feel free to reach out to us, thank you.
I'm sorry but I don't see a Skip Aggregation option in either the source or destination configuration, I have included sources and destination screenshots below.
I'm trying to configure a simple FTP to FTP transfer of multiple files
The skip aggregation field is available when you choose the option of generating files from record.
When you simply move files (download a file and then export a file), you do not have to provide timestamp or gui for the destination filename. This is what I put in the destination file field name:
