I'm struggling with this for a few days already, any help or pointers would be greatly appreciated.
I have a simple need, pull a saved search from NS and send the results as a CSV to multiple recipients.
I can't seem to figure out how to do this since as soon as my first step is an export from an NS saved search, it processes record by record and I end up with hundreds of emails.
Hi Chaim,
You can already do this directly from NetSuite, no need to build an integration :-)
On the saved search settings select the email tab:
Hi,
Netsuite doesn't allow to send to multiple recipients and you can't use a specific filename
@chaimpaperman you probably need to use a file provider in the middle and string 2 flows together. The file provider could be NetSuite file cabinet, Google Drive, etc. The second flow would then get the blob of the aggregated records and attach it to email. What email service are you using? Gmail? Outlook?
