Fix for Matrix Items with Multiple Prices - NetSuite to Shopify
In case this comes up for anyone else I found a fix for Matrix Items from NetSuite that have multiple prices and therefore cannot use the Base Price across all Items.
Remove the Base Price from the Search Criteria. Then it should return all your products and depend only on the product.variation[*].price field that is part of the mapping for each item.
Thanks for adding this solution to the Community, @gabeparr!
For anyone looking at this in the future. Check the settings tab → Products → NetSuite Price Level to Sync. I also have it in my saved search as criteria in NetSuite.
